bleed screw spanner size
Tried to open bleed screw on rear caliper to bleed the brakes, 8mm spanner not tight enough on nut will not turn, 7mm way to small! Have i rounded off the nut or do i need a special tool to open the screw?
V6 MX-3, Black, 17" gunmetal chromes with 205/40/17.
Now gone: Autozam AZ-3(Jap spec MX-3). 91, 1498cc DOHC 120bhp as standard. Manual, A.C, 17" black chromes with 205/40/17. Stainless Steel Exhaust,Pipercross Filter, Eco-tek valve, Strut brace, Racing steering wheel.
- PATDIESEL
It is a 7 or 8mm. Check that your tools are not crappy. I saw a tool set once that had a 10.5mm socket that was labeled a 10mm . (wouldn't fit a 10mm or 11mm nut) All the other tool sets fit the same nuts just fine.
No kidding...
No kidding...
