what happens whemn the oxygen sensors go and no codes?
hmm trying to figure it out still nd well its fuel related. so.. ok how does ones car react when oxygen sensors go? what about the idle control unit underneath the throttle body? my car will drive fine when cold... a few minutes later little by little it starts to missfire. I guerss basically the question im trying to answer is what does a car do when the oxygen sensors are bad? I pulled them out and they are black , cleaned them but well yeah.
-hec
yes but well trying to be a bit more clear "what does an automobile do when these devices are bad" ? anyone?
-hec
9/10 you will get the red light of death (aka CEL) so its porbably not a oxygen sensor problem.
Whens the last time you had a tuneup? My car misfired, irradic idle until i got tuneup.
Question, car driven cold? What do you mean, you just hop in and go...
Putting on your seatbelt....5 seconds
Not waiting for car to heat up...20 seconds
Getting to your destination...30 minutes
Waiting for your car to get fixed....6 hrs wait time + labor.
Wishing you spent 1-2 minutes letting your car warm up.....priceless.![Idea :idea:](./images/smilies/icon_idea.gif)
1. little to no feedback to ECU on mixture (ie: usually rich) so it runs open loop (preset fuel maps based on TPS, EGT, VAF/VAT and MAP sensors)hgallegos915 wrote:yes but well trying to be a bit more clear "what does an automobile do when these devices are bad" ? anyone?
2. usually CEL with codes 17, 24, etc related to EGO sensors
3. reduced economy (worse fuel mileage)
4. increased fuel washing oil off cylinder walls / fuel into oil leads to increased chance of wear and decreased oil life due to presence of more
fuel in oil. 1-2% in the crankcase is BAAAAAD
93 White MX-3 "Ebay special"
94 Green 626 V6 5-speed "family car"
94 Mazda B2300 SE "project turbo truk"
im starting to blame iton the ditry, im going to go get yet another exchange ..i hate checker.. and I hope its the disty.
-hec
I give up, shops dont wanna help, checked doesnt wanna help, no one knows whats wrong..im selling it for 800 dllrs or best offer or if it does not sell, pulling engine and sending it straight to a dump yard. Ill take pics as it is being towed to the yard if it doesnt sell.. what a waste of money.
-hec
I give up, shops dont wanna help, checker doesnt wanna help, no one knows whats wrong..im selling it for 800 dllrs or best offer or if it does not sell, pulling engine and sending it straight to a dump yard. Ill take pics as it is being towed to the yard if it doesnt sell.. what a waste of money.
-hec
-hec
I know when my O2 sensors were going, I was getting a slight misfire, I didn't even notice it with my untrained ear, curtklze pointed it out, but i also had no CEL codes indicating it either. It's possibly that they would be bad, but not bad enough to give a code. Also, you have a KF, can you get CEL codes with a KF ECU?
hmm dont want to jinx myself... but well here it goes.. I THINK i found the problem.. ok underneath the dash theres a ton of wires (harness to the fuses) I had melted wires touching.. i think it may have friend my kf ecu..not sure yet. Anywho i corrected the wires and am still going to the shop to have that rewired. I put on the k8 ecu and it runs fine. May missfire from time to time so thats a good indication o2 sensors. Whats weird is that it runs perfectly with k8 ecu. Anywho.. Also the fuel pressure regulator NEEDS that solenoid..it was just getting vacuum causing me to run lean . I still dont trust the car ..been driving around my neighboorhood for a few hours and i get missfire when i turn..indicating the wires underneath need to be fixed. wish me luck please. If i do sell it id sell the whpole car for 800. including good new engine and tranny.. thats if i cant fix it.
-hec
