How do you connect the horn with aftermarket steering wheel?
mxprecidia
i have an aftermarket steering wheel and hub. I am having a problem trying to figure out how to connect the horn. There was a clock spring with ribbon wire (stock) for the horn and cruise control wiring, but that doesnt seem useful anymore (especially since I broke it). how can I wire the horn so that the wire doesnt get twisted and tangled up while steering? I already rewired the cruise control, that was easy enough to relocate. but thanks.
www.illegalCustoms.com
Tri-State Area Car Club
my bro had the same problem with his sunfire. he bought these horn buttons from sparco that look likenos buttons. they were pretty easy to install and they look kinda cool also.
95 rs with custom short ram air, b&m short throw shifter, probe 2.0L header with 2 1/4" exhaust all the way back, catco high flow cat, apc high flow muffler with 4.5" tip, accel 8 mm wires, blaze red, cf altezzas, gun metal 17" mr7s, slotted cross drilled rotors on the way with hawk hps pads, red and white interior, other then that its stock.
This should help you out.
http://www.mx-3.com/phpbb2/viewtopic.ph ... hlight=hub
