I Think my Clutch is going
A forum for Drag Strip/Track Racing Discussions. (NO Street Racing or Kill Stories, they WILL be deleted.)
fastguy18
Post by fastguy18 »
I was at the track today and my times have been going up ever so slightly in the past week and when i drop it it does a smaller burnout so im not sure what the problem is.
WTF
WTF?
Post by WTF »
Can you rephrase wuth more detail or be more clear on what you are trying to say?
How can I remove Mazda Enthusiast?
Rick Johnson
Post by Rick Johnson »
How much does it slip when you shift? does it take a second or 2 to hook up?
deathman
Post by deathman »
you well have to give more info for anyone to help you out
it's on the probe are now, but it's moving to the mx3 soon.
m62 suercharger, megasqurit, headers,custom exh. 9lb. flywheel, stage3 clutch, & so much more.
http://www.cardomain.com/ride/1301296/1
SpikeDerailed
Post by SpikeDerailed »
When shift does your tach climb up but your accel is very slow? Like only 25% of the power is actually being transfered to your transmission.
n2ogsze
Post by n2ogsze »
Just replace it. Very easy thing to do. I can pull an entire kl/tranny out of my mx3 in 1.5 hour (with the help of one friend). Oh, I've got a lot of extra exhaust parts than most...
T61 powered KLZE
andthisguy
Post by andthisguy »
cowboy the fu ck up!!!!
just replace the bi.tch... consider resurfacing that flywheel and change that main seal while you're at it... nothing worse than a worn out clutch.. you'll love that new one... just stick to street/strip style..
Return to “Drag Strip/Track Racing”
