So how many people here have Nitrous Oxide on the V6?
How many people around here on MX-3.com have a Nitrous Oxide System?
How much money did you pay?
How much of a shot are you running?
What engine is it on? KLDE? KLZE? K8?
(Stupid Question) Does there have to be any parts that have to be made specifically for the MX3?
Last edited by Juans_93_MX3 on October 23rd, 2005, 10:14 pm, edited 1 time in total.
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
- MX-3 Money
- relisys_3200
- vozaday2000
Rick is running a 75 shot on his ze
http://www.cardomain.com/memberpage/730367 - UPDATED!!!!!!!
'94 MX-3 GS KLZE, KL01 Cams, Fidanza Flywheel, Centerforce Dual Friction Clutch, WeaponR Ram Air, 2 1/4 exhaust, Nichi Neptune Rims, Toyo Proxy 45 Rubber.
![Image](http://memimage.cardomain.net/member_images/10/web/730000-730999/730367_31.jpg)
Im about to install my ZE in my SE and plan on running a low shot around 40, just so i make sure the engine last awhile
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
- vozaday2000
from what i have picked up it would be best to run a wet kit. there should be some topics on it in the forced induction forum. but run a wet kit, a 75 shot should be fine. and from riding in Ricks car let me tell you a 75 shot is f*cking fast. on a klde you might be able to run higher though. basically just hook the wet kit up into your intake after the vaf. if you want to run a dry kit you will have to place another fuel injector to put in the right amount of fuel. you might want a wideband 02 or even a a/f guage to make sure you don't run lean.
I'm running a 75 shot, with a dry kit converted to a custom wet setup. You can get a used dry kit for around $350-400. If you want to go wet they cost a little bit more but are safer in the long run and will yield more power. Honestly tho nitrous is cool and all, but it isn't a long term solution the refills add up quite quickly at ~$75 a fill.
![Image](http://i255.photobucket.com/albums/hh134/Mazstylez/sig75.jpg)
