Smells Like Fuel
speaker_hmong
Smells Like Fuel
Post by speaker_hmong »
My Vehicle seems to smell like gas once it has been running and it comes to park. I dunno if my fuel lines are leaking or what. Any suggestion as to what might be going would be appreciated.
thanks.
vozaday2000
Post by vozaday2000 »
let it run and look under your car and look for a leak. if it is coming out some place then it will likely end up on the ground.
http://www.cardomain.com/memberpage/730367 - UPDATED!!!!!!!
'94 MX-3 GS KLZE, KL01 Cams, Fidanza Flywheel, Centerforce Dual Friction Clutch, WeaponR Ram Air, 2 1/4 exhaust, Nichi Neptune Rims, Toyo Proxy 45 Rubber.
speaker_hmong
That is what is funny though, i don't see any leaks on the ground even if i let it run for a while. I am just wondering if it is coming from my engine bay.
speaker_hmong
Forgot to mention that i did remove the resonator. I am also wondering if that could cause it to smell like fuel all the time. Other than that there are no leaks or anything like that that i can notice, physically inspecting it.
Zoso124
Post by Zoso124 »
Its probably just your gas cap, I replaced mine recently because I could smell fuel and I couldn't find any leaks, problem solved.
Mike Evans
Gone:
speaker_hmong
I did replace my gas cap a while ago. I had lost the OEM one and i purchased another one designated for the x-3. The cap seems to fit on there pretty tight though too.
mitmaks
Post by mitmaks »
ive noticed it happening too, its time to replace cap
