Help - Could be emergency
Citizenska
Post by Citizenska »
When I turn the wheel to the left and right I hear a hissing sound coming from it.
93 MX Special Edition - Does have airbags
Just installed a CAI but I don't think this could be related. Just stated happening today, atleast I started noticing it.
-Chris
Chris
neutral
Post by neutral »
Is pwr steering fluid level ok? Check it by removing the cap. A visual ck from outside on older cars can be deceiving as years of a maintained fluid level can darken a ring that makes a quick exterior glance appear as if level is normal. Course it's possible your ride is just P.O'd at ya for some reason too and so it hisses :wink:
Image -Jim
UKMX-3
Post by UKMX-3 »
Dont worry about it too much until your power steering starts getting heavy, mine does the exact same thing, has done for about 2 years, its never caused me any trouble, maybe top up ur powersteering fluid levels.
Actually on second thoughts just to clarify,does it happen when you turn the wheel a little or when its at full lock?
Mines only happens when its a full lock.
Not sure what it means if its constant
