codes again
codes again
can any one help me find out where is the sensors for code 9(CTS) and code 69( ?).
- PATDIESEL
what do the codes mean, you will get an answer if you don't make us break out the repair manual and look them up.
To see what each code is and troubleshooting procedures have a look at my site below under "info". Code 69 is water thermosensor (fan). I'd say thats what your photo shows, you can always check the wire colours by looking at the wiring diagram.
Post back if you need some help - I'll have a look through it in the morning.
