Brake dust EVERYWHERE
So I finally got my car on the road 2 days ago and got home late last night to find brake dust all over my rims. The silver rooms turned near gunmetal and my new rotors have black strips on them.
When I installed the new rotors (brembo) with my new pads (KVR) the pads would rub against the rotors at one spot on each wheel.
I'm trying to figure out why this could be. The new brake pads didn't come with new clips like most pads to for new vehicles. The pads seem pretty loose. I also had my calipers painted, but one of the wheels is rubbing and that caliper isn't even painted yet.
Any ideas?
Any ideas?
Chicks dig orange cars
- jschrauwen
Did you do the proper bedding in process with new pads/rotors? I just did a search for "bedding in" and couldn't find anything, but I'm sure I read something not too long ago on it.....anyone remember who or when it was posted?
- neutral
Gro Harlem posted some FAQ info on brake maintenance, prep, and break-in awhile back. It's also on his website here: http://projectmazda.com/tech/brakefaq.htm
Also, are your brake return springs intact? I think they are called "M-springs" on the front discs and "V-springs" for the rears per Mazda Shop Manual - little pre-bent lengths of spring steel wire. They keep the pads from riding on the discs when you're not applying brake pressure. I had to replace the front ones on mine after they corroded and disintegrated with age.
- jschrauwen
- neutral
You mention "bleeding" but it's "bedding" the new pads and rotors, not "bleeding," that John was talking about and that the above link gives the 30/30/30 procedure on. If the calipers and sliding parts aren't hanging up from wear or are partially seized, and you've followed the brake parts lubrication and pad/rotor bedding/break-in procedure from the above link, plus your M&V return springs are in good shape, I don't have a clue. Hopefully someone else will though, or maybe you'll see a decrease in dust during that 1st 1000 miles. Sorry.
- neutral
I have x-drilled brembos. Normal brembos are solid like regular rotors & x-drilling and/or slotting is done as an aftermarket mod. Haven't really noticed more wear w/chamfered x-drilled holes. Slotting reportedly causes faster wear tho. JoBoMX3 doesn't say what type he has so I assume they are regular solid brembo rotors...?
- PATDIESEL
I don't know about the dust amount from a CF pad, but you also need to check that the wheel's lugs are properly torqued with a ft/lb torque wrench. The lugs hold the rotor to the hub and if torqued differently from one lug ot another the wheel may be sitting crooked on the hub and thus the rotor crooked on the hub as well. This may be your problem for the scrubbing at one spot on the wheel's rotation and the reason you are getting so much brake dust. Loosen the lugs and torque them properly, make sure the brake clips are on propperly (if you don't have them get a set from Mazda, they are not that expensive) and bed your pads properly, also make sure the calipers were properly greased so that the pads don't get hung on the rotor and constanly rub. Could also be bent pad slides (the metal rod that goes through the pad from one side of the caliper to the other) if they are bent they will not allow the pad to move freely and the small pad clips aren't strong enough to force the pad to move on a bent rod. Those rods need to be lean and smooth, make sure to grease them alittle too so that the pad can glide smoothly, just make sure the grease coating is THIN, you don't want that grease on the rotor or pad.
