it was makin the typical starting noise, but wasn't turning over enough
I have nothing here (just moved here 2 weeks ago) so I can't test the battery or anything, is there another way to test the battery without using a meter? there are headlights on, and my deck will turn on.
I tried gettin error codes, the check engine light stays solid and the oil light stays on solid (dunno if that's normal). Tried resettin the codes, and doin it again, same thing.
just a few mins ago I tried again, and now it sounds like its tryin to guzzle some fuel now, like a bit of a gargle, but still won't start, any ideas that might help me on what it might be, or how I can get it goin?
thank you
-Jim
