Realistic HP Gains??
- shutupturnaround
ok so heres the deal i just put on a 2.25'' exhasut with no cat and mandrel bent corners back to a magnaflow 2.25 in and out . i am also in the process of ordering an intake for a integra for my mx-3 and i was wondreing what kind of realistic HP gains i should expect??
- shutupturnaround
- mitmaks
upgrades work together, if you were to polish heads too I would see as much as 25hp with intake/exhaust/port and polish
shutupturnaround wrote:actually yes i did feel a signifigant diferance and it sounds great
Which engine do you have...? Stock 1.8 or a 2.5 KL (DE or ZE)...?
When this thing hits 88mph, you're gonna see some serious TIHS...!
- shutupturnaround
make sure you read the backpressure FAQ.
What engine are you running. a stock K8 or 4 cyl is services just fine by our stock 1 3/4" pipe (AFAIR). The muffler is the restrictor. I put on an aftermarket one which has a "silencer" in it, and I actually lose power if I pull out the "silencer". Granted at high speeds I gain a bit, but at the low end I lose power without it (and I gain with it in over stock).
So unless you are turboing or going to a KLZE/DE engine, there is no real point to go to 2.25" piping.
Gro Harlem
with intake and just that exhaust i'd be surpised if you got over 5whp with a K8
DONATE TO MX-3.COM
DONATE TO MX-3.COM
