Show pics of your engine bays!
spark plug
Painting my spark plug wires becuase they are blue and when your engine bay is red kind of sticks out.... They are NGK spark plug wires so i dont want to replace them so i say screw it take them off give them a good cleaning sand them a little bit lay them down and give them a nice spray of red. Came out perty good.
1994 Mazda MX-3 KL-ZE
- solo_ryder
painted
i sprayed a little on the VC to see if it would stick. I was Meaning to take it off but I didnt get to it yet. I want to take the VC off and paint it a nice silver. The paint i used is engine paint the kind you can pick up at walmart for like 4 bucks a can. If you are going to try spark plug wires it can be a pain in the a-- to do. You ever try paining anything that has a oil ly feel to it. Doesn't paint well i can tell you that. So what i did was i took off 1 wire first and i took some soapy water and cleaed the wire off (make sure you do not get water in the wire its self) then i cleaned it with some water (no soup) and then i took a 180grade sand paper and sanded the wire a little. (give the paint something to stick to) When you paint it start with a fine coat let it dry ( I got good resalts when i let them dry for like 2-3 hours ) after that you can do some more layers. I need to do one more layer on mine but they still look good.
- rsroadkilla
- atlantamx3
Courtesy of Perry
MX-3 Owners Club of Atlanta
Clemson Sports Car Club #72
MOCA tuned straight-neck KL-ZE '93 MX-3 GS : Updated: 03/05/06
- XxantwawnxX
Most improvement award
- atlantamx3
- cduBBz'915
Curtiss Denson
93' soon to be BP Powered!! with added goodies.......
(coming June '08)
http://www.cardomain.com/ride/349197
(coming June '08)
- babyblueMX3
you need to spend less time on the internet and more cleaning your engine bayAshesofPepper wrote:Lets see if this works...
supah ugly
award for dirtiest engine bay of all time !
lol just kidding, but it's true, haha
RIP 400whp ZE-T MX-3
