Show pics of your engine bays!
K8, KLDE, KLZE, BPT, 4cyl, IT DOSENT MATTER
Open up your hood and show us a pic!
(this is devoted to the new coming gallery I am going to make)
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
- babyblueMX3
- 93-Spec-Edn
- XxantwawnxX
Myh motor bay is too ugly to show off.
- solo_ryder
- XxantwawnxX
PFFFT get that bpt out of here! lol j/k
These pics are of my Black mx3 when i was moving the ZE from it to my teal one.
- papa roached
- XxantwawnxX
I want your manifold...im stuck with the probe one.
- papa roached
its mine, you cant have it
