19' RIMS on the MX-3?
will 19's fit?
http://members.cardomain.com/str8304 <p>"JUST TRYIN' TO BLEED THE BLOCK"
18's are too big, why 19's?
Go for it if you want to look like teh tru3 r1c3r!111
or destroy your handling/braking/acceleration by adding heavy-as-hell wheels.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
- David Witherow
i dont see what the issue is here many ppl have put 18's on their cars and had no problems with lots of room to spare a 19 will surely fit.....and about the wheels being heavy as hell....why not just get light weight forged wheels.....in some cases you could get a 19 with tires that weights less then the stock tires and wheels
i say go for it
i say go for it
You can do that and waste ALOT more money on wheels that are too big for the carDavid Witherow wrote:i dont see what the issue is here many ppl have put 18's on their cars and had no problems with lots of room to spare a 19 will surely fit.....and about the wheels being heavy as hell....why not just get light weight forged wheels.....in some cases you could get a 19 with tires that weights less then the stock tires and wheels
i say go for it
Not only that, you better have a alarm and other stuff because theifs will look at you car as a $3,000 dollar score (light weight 19 inch rims alone)
So go ahead, destroy your handling and since they are bigger rims, your braking WILL SUCK
Dont forget, your rims are now most likely to get bent
2008 Mazda 3
1993 MX3 GS
1993 MX3 GS
- Tunes67
Not too mention that wheels that big look fugly on a small car.. just my opinion.. but whenever I see a small car with huge wheels.. I cant help but think it looks much like a Hot Wheels or Matchbox car. Which is fine if you are into that.. but I think it looks dorky LOL
Tunes67
Tunes67
- Chronicle-Rod
- atlantamx3
Re: 19' RIMS on the MX-3?
I don't see anywhere in this post where he is asking for anyones opinion...304N wrote:will 19's fit?
Yes, with the right offset and wheel width- 19s will fit.
- Andrew_Pakula
find me a 19" wheel & tire combo in 4x100mm that weighs less than my stock 32lb 15's and i'll give you 100 dollars. YOU WONT! you probably won't find one under 40 lbs.
32 vs 40+ lbs? thats a VERY SIGNIFICANT difference and will be noticeable.
If bling blingin down the road is worth the performance decrease then go for it. It ur car & money & choice.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
- Andrew_Pakula
Haha, exactly!quicksliver wrote:19" rims + MX3 = GAY
You ever seen those Honda CRX's with oversized rims? They look RETARTED. Id' say 17" is perfect, 18" is decent, 19" is insanely gay.
Couldn't have said it better myself.
- Flashpoint2
- Chronicle-Rod
"find me a 19" wheel & tire combo in 4x100mm that weighs less than my stock 32lb 15's and i'll give you 100 dollars. YOU WONT! you probably won't find one under 40 lbs.
If bling blingin down the road is worth the performance decrease then go for it. It ur car & money & choice."
Let's face it - if someone is THAT into performance that they'll worry about a 32 lb difference in overall weight, they're not driving an MX-3.
