the passenger's side of the car was lifted up in the air under the jack, and i had all the lugs off the front wheel, but the wheel wouldn't come off... i tugged pretty hard and it just wouldn't budge... i could've pulled harder, but i pulled it as hard as i could while still feeling safe (didn't want the car to fall off the jack)... i used a mallet in hopes to pound it loose (thought maybe it was rusted on) but that didn't work.... i moved back to the rear wheel to make sure there wasn't something i was missing... i took the lugs off the rear and the wheel slid right off... what's goin' on here?
after i was done working on the car i looked under the car and i noticed that the spot on the frame where i had lifted the car up on the jack was all crumped, as if it were smashed!!! why would this happen? i swear that that crumpled spot on the frame wasn't there before i started, so y would a car lifted up on a jack crumple the frame??? the frame didn't appear to be damaged or rusted at all... what's goin' on here?
![Help! :help:](./images/smilies/smilie_help.gif)
