So I press my brake pedal AND....
Chasing_Size
Post by Chasing_Size »
It turns my accessories on... anything hooked up to accessory turns on... my indiglo gauges, my air fuel gauges, and when the cars off, and i press it, it turns the accessory on, so my car beeps, like the lights are on still, when i take my foot off the brake... it stops... HEPL!
1992 Mazda mx3 gs / 03 / ms8 intake manifold / klze 67mm bored TB/ Custom CAI / 2.5 Custom exhaust / Drift kit front and sides/ CF Invader hood / 17'' MSR gunmetals with chrome lip / Tockico Blues / Suspension technique springs / Leather interrior/ B&M SS / Fully customized interrior (Red and black) / Corvette Red 00 Paint w/ white,blue,gold pearl / Shaved altezzas w/ black trim/ Front rear strut bars / ze ecu ( I think that's all )
vozaday2000
Post by vozaday2000 »
wow, thats rather interesting. sounds like there may be a short in your car somewhere. is it just your accessories or do you head lights turn on also. take the park brake off and then push on the brake and see if your daytime running lights come on. if so it sounds like the short could have something to do with a ignition wire and when you push the brake the wire makes the car think that the key is turned up one notch (sorry for personifying the car but i couldn't think of a better word atm). feel free to jump in because these are just ideas
http://www.cardomain.com/memberpage/730367 - UPDATED!!!!!!!
'94 MX-3 GS KLZE, KL01 Cams, Fidanza Flywheel, Centerforce Dual Friction Clutch, WeaponR Ram Air, 2 1/4 exhaust, Nichi Neptune Rims, Toyo Proxy 45 Rubber.
2fazed
Post by 2fazed »
Yeah, my GS does the same thing. I don't know anything about it, cause it was this way when I got the car. It's like when you hit the brake, all the lights that comes on when you switch the lights on the first knotch. Dash, all the exterior lights(excluding headlights).
I'm guessing that something is touching the brake line? Once I'm done with my current project, when I start my 94 dash swap, I was going to look into that, cause I see the brake line wire adapters run up behind the dash.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
Chasing_Size
Yea, the two front marker lights come on to, its feekked, want to get it straightened out..
