Operating Temperature
On the V6 where should the needle be on temperature gauge when the engine is warmed up?
V6 MX-3, Black, 17" gunmetal chromes with 205/40/17.
Now gone: Autozam AZ-3(Jap spec MX-3). 91, 1498cc DOHC 120bhp as standard. Manual, A.C, 17" black chromes with 205/40/17. Stainless Steel Exhaust,Pipercross Filter, Eco-tek valve, Strut brace, Racing steering wheel.
Mine is again just past (above) centre, 1994 SE model.
A friends 1997 MX-3 is just below centre... (grr)
Mazda MX-3 Limited Edition
1845cc V6 DOHC
Custom ICE Installation
http://www.destr0yer.net/car-sig.jpg <-- click!
1845cc V6 DOHC
- papa roached
mine used to sit at center before i put in a true temp gauge
- Tunes67
Mine sits just slightly under halfway. Most likely the differences between all of our cars is the thermostat. Assuming the sensors are all functioning within parameters. That leaves the Thermostat. They are all supposed to open at their rated temperatures, however.. things like altitude, coolant condition, etc.. can all affect when the thermostat opens. And this will effect where your temp needle sits. If you think your needle sits too high on the gauge.. try replacing your thermostat first.. especially cause its far cheaper than replacing the sensor
Tunes67
Tunes67
mine was a little above center before i had the all metal radiator from radiatorworld.com affter i got it , it drives a bit under half way.
-hec
