Oh sh*t, In ten years I've never replaced mine. I will make it a point to get a new strainer from Mazda. Thanks much George!!georgechicken wrote:What you're referring to, mitmaks, is the "low pressure" fuel filter. For good measure, replace this every 3 years or so. daniel
Replacing Fuel Filter
- jschrauwen
- PATDIESEL
If you releave all the fuel pressure from the pump you'll need to prime the pump to keep from running it dry and damaging it. Just pop the gas cap and don't smoke while replacing the filter. It will squirt alittle, but it's alot easier then priming a pump. Or pull the fuse and let the engine run all the gas out. When your finished turn the car on, without cranking it, and let it sit for a few seconds before turning it over to refill the fuel lines.
Actually, that's great advice to prime the fuel lines after pulling the fuel filter... But just to make it a bit less painful, here's the easy way that most folks are unaware of... To prime the fuel system (this is Mazda's preferred and specified way of doing it, FWIW), open the diagnostic connector just in front of the firewall under the hood, and locate the terminal labelled "F/P". Take a jumper wire, bread twist-tie, paperclip, or anything metal that will fit, and connect that terminal to the terminal "GND". Now, turn the ignition switch to the 'on' position (do NOT start the car), and let it run for about 5-10 seconds (you'll hear a light 'whirring' underneath the rear seat to let you know its working). After waiting, just turn off the key, remove the jumper wire, and your fuel lines are re-pressurized. Good luck!
Daniel
Daniel
--Maybe the Hippopotamus was just a really cool Apotamus.--
- PWRD_BY_HKS
remove your batt and vaccum (spelling) and you should be able to see it, all you have to do is remove the clamps put the new one in and your good
Mx-3 Kid El Paso,Tx
Mx-3 Kid El Paso,Tx
jdmx-3 KID OF THE ![Image](http://img118.imageshack.us/img118/8885/3kidkn5.jpg)
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
VICTORIA RACING
