Compatibility Questions!
- jschrauwen
That ECU would probably be the same as mine, a KL01. Not sure if the KL01 was MT or AT sensitive.mxmaz wrote:Your car is obd-1. I'm thinking you would need a kl02 vaf and an ecu out of a 93-95 mx6, probe gt, or 626. And the intake manifold that comes on the klde will fit fine it only has a short neck.
Dragon1976_27
Well, I definately am staying with my standard tranny, I mean what's the point of doing the upgrade if you have an automatic. Standard is the only way to go! I was unaware that ECU's were programmed differently for standards and automatics, but since they are I'll have to go hunting for a standard ecu. So if the MX-6 motor I have is 1996 does that mean I'll need an ECU from a 1996 MX-6 standard? Additionally will that mean switching to OBDii, as you stated that OBDii was standard for 96 and up?
- jschrauwen
So the KL01 ECU should compliment the KL02 VAF for his particular application??mxmaz wrote:If your car is obd1, keep it that way and get a kl02 vaf and an ecu from an obd1 car that has a klde engine and 5spd tranny. You wont be able to use an obd2 ecu even if your car is obd2 because they werent interchangable to the mx3's harness.
