turn signal trouble
turn signal trouble
I was wondering if anyone could help me. My turning signal is sticking when I turn it comes on and stays on usually. I think it might be something in the steering column. I don't know. Its really annoying.<P><BR>Larz
Re: turn signal trouble
when you turn the wheel to the left it puts the left signal on at a certin point in the wheel ? <BR>if so the wheel is bent what you what to do is find out where in the wheel its bent (you will be able to hear it) and give it a GOOD PULL back should fix it
Thanks whitefish it seemed to work
