interior light bulb sizes
Kokiriwave
Post by Kokiriwave »
anybody know the sizes of the light bulbs inside the car...
instrumental cluster, the buttons on the left/right, the climate control..?
can they be changed?
I want MAZDASPEED!
MY WEBSITE:: http://kingmx.net
Gro Harlem
Post by Gro Harlem »
the ones behind the gauge cluster are 168's (3w) or 194 (5w's) depeding on how bright you want them.
I'm not sure what size are behind the HVAC controls, probably the same size.
they are a pita to remove, you gotta remove the guage cluster or HVAC panel completely then unscrew the bulbs and replace them individually. And since you can't have the stuff plugged in at the same time, its hard to know hwich bulb to replace.
DONATE TO MX-3.COM
