hard start when cold-not only problem
hi, just bought 92 mx-3 4 cyl. check engine light is on when we bought car-problem is hard to start when cold but when car dose start if turned off before car warms up car will not start again for several hours local parts stores say they do not have diagnostics for that year of car any ideas greatly welcomed
Check the diagnostics yourself......black diagnostic box under hood(close to firewall, driverside) use a piece of wire or paper clip and jump it form TEN to GRND!! Turnthe key to the acc position and the code(s) will come up atthe check engine light(longer blinks and faster blinks) let us know what they are they we could help you out more!!
reply to joey on diagnostic
thanks for info. jumpered TEN -GRND put in acc position check engine light blinked 3 times---and kept blinking intervals of 3
- mitmaks
sounds like problem i had with civic, it turned out to to be cap was cracked, also change your coolant temp sensor, that should help with cold starts
- neutral
Follow this link & scroll to the bottom for 92 MX-3 Factory Manuals. http://www.books4cars.com/result2.htm?f ... &Submit=Gomaddog8664 wrote:what would be the best manual to buy for the mx-3
Chilton's can get you through some stuff but can't beat the detail in Mazda Factory Shop Manuals. Not cheap but they pay for themselves many times over. If books4cars is more than you can spend, you'll see em on Ebay every so often usually at well under $50. Either the 92 or 93 factory manuals would cover your model.
