f/s: B6t partially port & polish head
I bought a package of b6t parts and with it came a cylinder head that has been ported and polished on the intake side but not the exhaust side yet... i don't plan on using it and am looking to sell it plus a gasket set for the engine for $140 shipped... will ship to canada also... but if it costs more i will have to increase it accordingly. it should arrive in the next few days so if anyone is interested let me know.
ProjectMx
My BP and AWD build thread
Cardomain
93 Mx-3 GS with bp and GTR AWD system
93 Escort GT daily driving
Cardomain
bump
ProjectMx
Cardomain
Cardomain
is the B6T a dohc?
I've never been that sure about it. Will it fit on a good 1.6 block from a 94?
93 GS, ATX to MTX swap, chrome 16x7, upper strut bars, SRD LCA bushings.
Upcoming improvements: Tokico/Eibach struts/springs, energy suspension LCA bushings
94 RS MTX, Engine swap completed, ALIVE Again!
95 RS ATX, parts car/project X
- papa roached
its DOHC and it should fit
yes it is from the b6t.. and yep they are DOHC... and according to everyone the b6t head fits our engine
ProjectMx
Cardomain
Cardomain
What is the difference between the b6t and b6e (or ze) heads? would it use the same valve cover?
Sorry for all the questions, just wanna see for sure how this will work. Thanks!
someone else could probably answer better but i think the valve cover fits but you have to use the sohc intake manifold (but that also means you can upgrade to a 60 mm tb)
ProjectMx
Cardomain
Cardomain
this is a great deal normally a head costs around 100 or more and the gasket set is around 30 at least also... then add shipping comes to a lot more than i'm selling this set for
ProjectMx
Cardomain
Cardomain
$110 shipped in the states... c'mon someone must want b6t cylindar head... comes with everything (including the gasket set) all you will need to do to it is port and polish the exhaust side and pick out some good cams and then put it all together and you'll definantly get some good gains out of it.
ProjectMx
Cardomain
Cardomain
could you send me a few pics? mlindsey78@yahoo.com would very much appreciate it!
i'll try and get pics tonight and email them tomorrow
ProjectMx
Cardomain
Cardomain
Im definately interested.
Im interested most definately, send me some pics as well in case it dont work out with the other guy, barbarino@gmail.com
thanks.
thanks.
i don't have online at home right now... and still tryin to find my room mates digital cam... i'll post pics hopefully soon
ProjectMx
Cardomain
Cardomain
pics sent.... oh and i'm including the b6t valve cover also still just 110 for everything shiped in the states
ProjectMx
Cardomain
Cardomain
