wheel hop
wheel hop
well when i take off the line i get some bad wheel hop anyone know how to get rid of it and also would a strut bar help any ?
CTC Racing
92 1.6L
93 323 Tranny, ACT clutch, Exhaust, cold air intake, MSD Blaster 2 coil, MSD 8.5mm super conductor wires NGK V-power platinum plugs,engine dress up,custom interior(almost done), GS front bumper, GS 5 spoke wheels Painted white.
92 1.6L
yah a few things can help. stickier tires:), suspension setup, solid motor mounts.
thanks what kind of suspension setup are you talking about ?
CTC Racing
92 1.6L
92 1.6L
- babyblueMX3
what he saidDavidOS wrote:yah a few things can help. stickier tires:), suspension setup, solid motor mounts.
stiffer springs will help
RIP 400whp ZE-T MX-3
- babyblueMX3
I don't have any good mounts, don't have sticky tires but i do have springs and struts..Almost no wheel hop with 15's but with my 17's wheel hop like crazy
Nallboy
My guess on that would be that the low-pros on the 17s don't flex like the bigger tires on the 15s would. When I take my car to the track, I'm going to wear some 14" racing slicks.babyblueMX3 wrote:Almost no wheel hop with 15's but with my 17's wheel hop like crazy
'93 GS sporting 31 ZE, 36 ECU, Millenia IM & TB, Beefed up tranny, Fidanza FW, CM Stage II-R, Al UDP, HS Headers, MF Hi-Flow CAT, 2.5" Piping, CAI, MGC Wires, MS Mounts, B&M SS, Bronzoils, SS B & C Lines, Brembos...more.
Oh yeah, I have a stock ATX 92 RS too.
"Everyone wants to live life in the fast lane; I have more fun weaving through traffic."
- papa roached
i get huge wheel hop on my 15s, but suspension is stock for right now
- Josh
the two things that will eliminate wheel hop totaly. one is Solid or filled moter mounts. takes away all wheel hop. and if for some reason it doesent SRD makes poly A arm bushings, and that will cure it. thats all you need. suspension and tires will help, but the mounts and bushings are KEY.
the suspension helps by keeping the rear stiff for a good take off.
My car wheelhops like hell. It is terrible. I have solid (filled) motor mounts that are totally perfect (checked them the other day) and ZX2 struts. Instead of a 2nd gear chirp I have 2nd gear wheelhop.
The chassis has 109k on it, so nothing extreme. All bushings appear to be okay. I just think its the suspension geometry to blame for the 'hop.
I also have stock 15's and street tires. The only real way that I can avoid wheelhop when launching is to feather the clutch. If i was to drop it, i'd have a broken tranny by now.
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
- Josh
with that much power and weight over the front you shouldnt have any. try lowering the tire pressure alittle, since your on 15's you could probably go like 10, 20psi from max when you launch. that might help.rebel2k4 wrote:My car wheelhops like hell. It is terrible. I have solid (filled) motor mounts that are totally perfect (checked them the other day) and ZX2 struts. Instead of a 2nd gear chirp I have 2nd gear wheelhop.
