flexable exhaust
- goldsberry1
flexable exhaust
i was thinking of useing a 3" flexable exhaust pipe for the down pipe from the turbo. since i hve the whole system out i was thniking of trying that for a while. i would wrap it in insulation and use a insulation blanket i have from work. what do you all think? after i break it in i will be pushing close to 15 psi.
92' mx-3 gsr, built engine, forged internals, p/p ze heads. t3/t4e .63/.60 turbo, udp, msd ignition, millenia s injectors, millenia im, water cooled intercooler, afpr, fmu. running at 7 psi right now
- Josh
Re: flexable exhaust
thats what i did origionally. i used a small piece of flex for the down pipe. just till i got onw made. so for about two weeks. its only really ok for temp jobs, when you dont have the money for the good stuff.
