HELP!! W/ Clear Plastic
I need to know whhat i can use to take paint off of plastic with out it eating through the plastic. and then i need to know if i can use like plactic polish to make the plastic all clear again....help me please
<img src="http://images.cardomain.com/member_imag ... 2_full.jpg" alt=" - " />
Re: HELP!! W/ Clear Plastic
Depends on what type of plastic and type of paint.
its like a lense to a fog light.. clear kinda hard, and i wanna say its spray paint on it..
If it is a very important piece of plastic to you, take it to your specialized plastic shop. They may give you a suggestion based on what it is. I can't suggest anything but mechanical way of removing it. 2000 grit wet sand and then polish. But try and see if anything Chemical will help. Good luck.
I had to do this.. What ever you do do not use paint stripper..
JDM is right.. use a very very fine wet sand paper.. It may take a while but it does work.. Buff it really good and then I would clear coat them.. This is what I did to my blinkers and they turned out better than new!
Meguiers Scratch-X then some platic polish worked for a paint scuff on my one headlight. Of course it took a very long time. You just gotta be careful and use a really fine abrasive.
