-Had codes lifted off computer at a tranny shop
-Indicated faulty vehicle speed sensor
-Replaced speed sensor, took car for test drive. All was good had forth gear back no problems.
-Few hours later took car out again. Hold light immediately blinking and water temp gauge going up to 95% of maximum. Swore on car repeatedly. Asked god why me.
-Took car for highway drive shortly thereafter. Ten minutes into drive light stopped flashing and temperature went back to normal. Was getting 3000 rpm at 120kph (normal). This meant I was obviously in 4th.
-Parked car for an hour, on drive home no hold light, no problems getting into 4th gear. All is well?<p>
So Im wondering if my problem is indeed fixed? The old VSS was gone(could turn the gear with nor esistance) so that was definately a problem. Should I put some extra tranny fluid into her since she was having this 3rd gear issue for about a week? <p>Im just dreading that a problem I think is fixed isnt actually solved since it just randomly started flashing the light at me again today and heating up.<p>Can anyone offer any suggestions?<p>Update: Took car for another drive at low speeds. Hold light blinking, car heating up as before. This time the light flicked off for a few minutes and 4th gear was available again then it came on again. Im really baffled by this
