well i am running out of projects. anybody got any ideas or things they want done so they can see what a mods gonna look like?????
here is my latest project
original
both cars lowered, celica changed to blue and muffler tucked under bumper more.
update on celica pic...shaved door handle and emblems, removed pin stripe, and shaved rear key hole and rear antenna.<p>[ March 18, 2003: Message edited by: mzdspd ]</p>
If you want can you photoshop this exhaust onto my car? I just want to get a rough idea. Again only if you want to! Heres some pics, hopefully good enough to use. <p><p><p><p>The last one is just incase you have a better pic of that type of muffer so put on. Its the magnaflow DTM 3 inch tip model. Thanks again!
Mods:
- ZE, Mike seli 214 intake cams, Ported n polished heads, Interprep valve springs, DE retainers, rebuilt bottom end, toga main and rod bearings, toga hv oil pump, CZT 67mm tb, mbx udp, ported intake mani, SS headers, 2.5inch full exhaust, racingbeat muffler, highflow cat, megasquirt v2.
new toy, 86 TII rx7, JDM S5 motor/turbo, + alot of other goodies
btw guys when u want me to put kits or what ever on ur cars try and get them at the same angle for best results T-rose did a good job wether he meant to or not.
Mods:
