Hi,
The inside top part (the bit below the window) of my passenger door is starting to rattle badly against the glass (i think). Also when I push it it seems loose.
How do I fix Its really bugging me.
Paul
Inside of door rattling
Re: Inside of door rattling
Take the door panle off, where the window channel is, you will see some clips under, on the actual panel. Bend them so it does not rattle. Reinstall.
Thanks, I'll give that a go
thanks, that did the trick. I pushed the clips in a bit and wrapped some padded tape round them No more annoying noises
Paul
Paul
