I don't know if any of you have heard of Whiteline, but they are a pretty well-known Austrailian suspension company. They make full suspension kits for the Mazda 323 GTX or GTR as well as the Ford TX3. Most of this stuff will fit the MX-3. Whiteline is pretty well known to make damn good quality products. I've never heard anything bad about them. They recently opened a WEBSTORE which offers shipping to the UNITED STATES!! <p>Before you read the parts list. Please note that the swaybars will NOT fit the mx3. The front one might, but the rear will not. The endlinks, camber, caster, strutbars and struts/springs will fit however.<p>Here is the URL to their website: http://www.whiteline.com.au <p>I prepared a price list and part number list of all the stuff for our cars. <p>HANDLING PACKAGES
-Handling Pack (includes 20-24mm adjustable rear swaybar, front swaybar urethane endlinks, caster anti-lift kit, and two sets of camber bolts). Price: $453.64 AUD which is $285.80 USD<p>-Sports Pack (includes 330mm front springs, and 300mm rear springs, and 4 adjustable koni shock inserts). Price: 880.91 AUD which is $554.98 USD<p>-The Works (inclues everything in Handling and Sports Pack's). Price: 1,268.18 AUD which is 798.96 USD.<p>-The Works Adjustable (Includes everything in handling pack, but comes with adjustable coilovers and struts instead of koni inserts and lowering springs). Price: 3,204.55 AUD which is $2018.07 USD.<p>SUSPENSION PARTS
Part # | Description | AUD Price | USD Price<p>120230 | Laser KF-KH Mazda 323 rear left strut | $168.18 | $105.95
120210 | Laser KF-KH Mazda 323 front left strut | $168.18 | $105.95
120220 | Laser KF-KH Mazda 323 front right strut | $168.18 | $105.95
120240 | Laser KF-KH Mazda 323 rear right strut | $168.18 | $105.95
BFR43Z | H/duty swaybar-rr Blade adjust. (20-24mm) | $204.55 | $128.87
SPF903K | SuperPro poly bush kit (front swaybar) | $15.92 | $10.03
KCA412 | Camber adj bolt kit-12mm (2 bolts) | $71.82 | $45.25
KCA324 | Control arm-rear bush caster adj. | $117.27 | $73.88<p>KCA324X | Control arm caster adj. & Anti-Lift | $180.91 | $113.97
KSB560 | Adj. Front strut tower brace | $162.73 | $102.52<p>KSB537 | Adj. Rear Strut tower brace | $162.73 | $102.52
BFF33 | Heavy duty swaybar-fr (24mm) | $145.45 | $91.64
BFR43 | Heavy duty swaybar-rr (22mm) | $145.45 | $91.64
Here is a link to the parts list for this stuff: http://www.whiteline.com.au/docs/fact_sheets/CK_Maz_323GTX.PDF <p>Here is an article from a magazine that installed this suspension kit on a Ford TX3:<p><p><p>
Whiteline Suspension Components
DONATE TO MX-3.COM
DONATE TO MX-3.COM
- millionflame
Re: Whiteline Suspension Components
Awesome, thanks for the information.<p>At the very least, it gives us stronger endlinks and such for the Corksport bars.<p>~A
~ Millionflame (94 GS 120K)
- Custommx3
- Site Administrator
Great info.. copied to suspension FAQ<p>[ April 30, 2003: Message edited by: Custommx3 ]</p>
ehh. oh well. They are universal endlinks anyways. The ones i bought for my Protege were about 2" shorter than my stock ones, but still fit. <p>So there isn't any way to really know if these whiteline ones do or don't fit .<p>How is the front bar different? are you sure its different on the RS's too? i thought the 4-banger MX's used a Protege front suspension for the most part. I haven't really compared them in a junkyard tho so i'm just assuming.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by Gro Harlem:
ehh. oh well. They are universal endlinks anyways. The ones i bought for my Protege were about 2" shorter than my stock ones, but still fit. <p>So there isn't any way to really know if these whiteline ones do or don't fit .<p>How is the front bar different? are you sure its different on the RS's too? i thought the 4-banger MX's used a Protege front suspension for the most part. I haven't really compared them in a junkyard tho so i'm just assuming.<hr></blockquote><p>
Wil, I think I worked on David's enough to know the difference. The endlinks will NOT work. The sway bar's "hole" is offset 90 degrees on the MX-3s, much like the way a 3rd gen Protege endlink looks. You cannot use the same style as we (1st genners) do.
-93 MR2
#129 E-stock
#129 E-stock
the fronts too? thats strange. I saw the way the rear is and i see what you mean.<p>don't get your panties in a bunch over it!! It isn't like i was declaring they would fit, i said they "might"
DONATE TO MX-3.COM
DONATE TO MX-3.COM
