Need help for choosing suspensions
I am a owner of 94 MX-3 with 1.6 4cyl. Right now, I am looking for a new set of springs and a new set of strut/shock (seperatily). However, my car has 4W ABS on. It is kinda hard to find such sets which can fit my car with ABS on. So is there anybody can give me some advise? thanks
- jaydog5678
Re: Need help for choosing suspensions
You can use...Eibach, H&R, Ground Control, suspension tech. <P>The only aftermarket struts I know of that you could use would be the Koni's, but they are not a complete assembly, they're inserts. You can adjust them too, but only while the strut is off the car. Kinda shitty [img]shrug.gif"%20border="0[/img]
Do a search for ABS. I think there's a post that talks about the nessicary modification to convert most struts to ABS compatible. I think it's drilling a hole, and inserting the bracket from the old strut, but I could be wrong....<P>Good luck
tk1138<P>There's not really anything I want to say over and over.
