how much coil do i cut on intrax
blazers101
Post by blazers101 »
i got a 92 mx-3 lowered with itrax springs on 17 inch rims with 40 rubber i want it to sit a little lower on the 17s how much coil should i cut if any?
precidian
Re: how much coil do i cut on intrax
Post by precidian »
I would recommend against cutting springs to lower the car any more... Rather you should look at getting Ground Control....<BR>with that setup you can lower it more than what you have now.... but on the MX I would not recommend going lower than 1.5" drop.<P>cheers,
Tom S. - '94 MX-3 GS-X Sparkle Green
I say, Ahmed. What is that thing you do when you're about to assassinate an infidel?
wgale
Post by wgale »
if you are not worried about getting it perfectly level, then only cut out small portions at a time, because there is no turning back. My friend cut the springs on his civic and the left side is noticably lower than the right. It's very hard to get it right, when choppin coils.
Zoso124
Post by Zoso124 »
DO NOT cut those springs! You cut them then they are garbage. The height will be off each no matter what, so will the weight handling capacity and a great risk of them snapping. Either get GC like Tom said or leave them alone.
Mike Evans
Gone:
