ABS vs Non ABS
codyhoover
ABS vs Non ABS
Post by codyhoover »
went lookin for new struts and there is different struts for ABS equiped mxs and non ABS ones. anybod know what the difference is if any?
-Cody
Green '92 GS
140db on 1 12"
pelado
Re: ABS vs Non ABS
Post by pelado »
Just a guess but I think it probably has something to do with an extra bolt hole or bracket for the ABS sensor wiring. Probably no difference in the strut internals.
ProtegeSTS
Re: ABS vs Non ABS
Post by ProtegeSTS »
correct
-93 MR2
#129 E-stock
kecco908
Re: ABS vs Non ABS
Post by kecco908 »
codyhoover, can you tell me what structs u find is fit for abs car
Buff1110
Re: ABS vs Non ABS
Post by Buff1110 »
u can use the regular non abs struts however you must secure the abs wire with a zip tie or something, most struts offered are for non abs equipped mx3's anyway<BR>Dan
Dan
92 Mx-3 Gs, KLZE Powered!! - SOLD!!!!
02 Tacoma TRD - Daily
93 Honda del Sol - New Project
