Rear Strut Bar installation
What's involved in mounting a rear strut bar. I just purchased a Reactive reat bar and I'm not sure how to start.
hi
Re: Rear Strut Bar installation
just take all the plastic pieces off around the strut towers, take out speakers, and rear seat belts, and then you will have to make a hole in the plastic, so the bar can go across the trunk, it should be pretty easy if you've done some work on cars before.<BR>good luck
Check out my ride and leave some feedback please!
http://www.cardomain.com/id/mradio007
depending on the design of the brace, you may need to alter the seat belt brackets a bit.. basically so the bracket can fit on over the brace comfortably.. <BR>and yes, you'll also need to cut a little bit of plastic out.. I suggest marking it out VERY carefully to make for a nice, neat job.<P>Hope this helps..<P>@ds..
- EUNOS 30X -
