TE04H Mistsubishi Turbocharger
wkdmx3gsr
Re: TE04H Mistsubishi Turbocharger
I had mine on a dyno in Feb. and pulled 240ftlbs of torque with a 75 shot of nitrous dry on a kl-ze motor, ms8 intake manifold, 6 puck race clutch, 9.5lb flywheel, crank pulley. not bad for stock internals. pulled 12.4 @109 mph with full interior at the track in the 1/4. on NT555 drag radials.Now I tore the car apart to turbo the motor. I work for a shop called swiftmotorsports in Connecticut and I got the car sponsored by Nitrous Express going direct port with a maximizer and getting the turbo piping from Precision Motorsports Online. I got the Heads ported and polished and 45 degree valve job with new stronger valve springs and new valves external ignition system only going to run 8psi to 10psi because i really dont want to replace the pistons yet to run more boost i'll try this set up for the new year and see what happens. Tyring to get into the low 11's maybe high 10's for the new year. Also doing a full front end conversion of an RSX headlights front octane bumper, custom bullet fenders, and custom fiberglass hood already started. Should be done in mid Feb or early March. Pictures will be posted at our website at swiftmotorsports.com. We just finished putting on a twin turbo kit on an 2004 G35, putting 450hp on 8psi thing is sick!!!!!
1992 MAZDA MX-3 GSR 2.5LTR V-6
2005 SUBARU STI
2004 NISSAN ARMADA
http://www.cardomain.com/id/wkdmx3gsr
http://www.netuners.com
2005 SUBARU STI
2004 NISSAN ARMADA
