im doing my search like everyother forum requires before one opens their mouth.
im thinking of doing a twin turbo setup.
i have 2 turbos an ht12 (same as found on an rx7)
and a ht15 (these turbos came off of my mazda cosmo engine)
now the intercooler would be custom and the bov would be placed on the outlet (cold side)
the waste gates would be set and .7bar (10psi) or less. I figure the flow would be equal to that of a t3 at 5-7psi. I hear that the k8 can take 8-9psi (w/o a huge turbo... lets not discuse psi vs flow please) The MAF sensor would have to saty if i am correct? Like my turbo miata B4 I went w/a link ECU. I was planning on using slightly larger injectors and a FPR w/ a 10:1 disc.
this all start because my clutch is slipping and I miss my turbo miata.
i have an engine diagram in hand and i see that they need to be there!! this car needs more power think this will work? w/o too much of a pain? OH and there are not many twin turbo mx-3's out there that i know of!!!
let me get your thoughts!
1993 Mazda RX-7 Touring Edition
