Wide band o2 monitor
curtklze
Post by curtklze »
here is a link to a wide band o2 sensor system.
it costs about $350.00 and comes with a bosh wide band o2 sensor, it has data logging capabilities as well.
just read the site for all it can do and a complete list of accessories and prices.
this system seems to be the most affordable if all you want is a proper way to data log and monitor your TRUE Air/Fuel ratio for tuning your FI setup.
http://www.innovatemotorsports.com/products.php
LM-1: Digital Air/Fuel Ratio Meter
Tuning an engine for maximum power previously required long trial-and-error sessions on a dynamometer. With the LM-1, precise AFR measurement allows the user to correctly adjust many variables- including carburetor jetting, fuel injection, turbo fuel curves, etc.- without long and expensive dyno sessions. The meter’s digital signal processing technology provides data on exactly how rich or lean an engine is running at any load. The LM-1’s self-calibrating circuitry also compensates for changes in temperature, altitude, and sensor condition.
• The instrument can sample and store the air-fuel-ratio and the other sensor data internally in operation for later analysis on a personal computer. At a sampling rate of 12 samples/second the instrument can store up to 44 minutes worth of data in non-volatile memory. The data can be downloaded to a personal computer using a standard serial port and viewed/analyzed by the included software or any standard spreadsheet program
The standard LM-1 includes a Bosch wide-band oxygen sensor and cable, cigarette-lighter adapter, serial cable for PC connection, 9V battery, exhaust bung and plug, CD and manual. The LM-1 ships with a Bosch sensor, however, it can also function with other wide-band sensors, including Honda/NTK and VW sensors.
• Available accessories include auxiliary input cables, alligator-clip power cable, exhaust clamp, analog output cable, and Aux. input expander. Additional accessories include a dash-mountable display and AC adapter.
The LM-1 sells for $349, including the oxygen sensor (Bosch LSU4.2), 10' sensor cable, 10' power cable, serial PC cable, and software
<img src="http://www.innovatemotorsports.com/imag ... cts_01.jpg" alt=" - " />
Yes, I AM a bastard
Return to “Forced Induction”
