Does anyone have a Supercharged KLZE?
Re: Does anyone have a Supercharged KLZE?
Sounds interesting. A built up kl03 at 14 psi putting only 300 hp down seems fairly conservative to me. Didn't david coleman put down nearly that much using stock internals running lower boost?
My Cardomain site
My Cardomain site
- mrspanky79
Coleman is not running boost he has just a klze
War does not determine who is right, war determine who is left!
94 mx3 GSX Stroked Turbo'd and Intercooled
99 vitara 4x4
99 vitara 4x4
Sounds like Joe's lime green mx-3. I think he said 2.9 and not 2.7. I think the S/C pulley setup was Jeff Abram's design.
OSKY
95 MX-3 GS ZE Turbo: MSnS-extra, AEM WB, Blitz boost controller, MSD 6A w/ Blaster2 Coil, ZE disty, Redtops @ 550, Walbro 255, Garrett T3/T04E 60 Trim w/ .63 A/R, 38mm Deltagate Mark II @4psi, FMIC, Apexi BOV, CM Dual friction, 4-6.25 Kickers, 2ch Alpine V12. That's Alll.
http://www.pakfeifertuning.com
- mrspanky79
yep its joe, and yes he coppied jeffs but i remember him telling me 2.7l
99 vitara 4x4
99 vitara 4x4
Unless I have the wrong David Coleman in mind, he had a supercharged, then turbo charged kl03 at one point. That is the set up I am speaking of.
My Cardomain site
My Cardomain site
- mrspanky79
Your thinking of Jeff Abrams
99 vitara 4x4
99 vitara 4x4
joe happens to be one of my best friends. the setup is from thomas knight and, in our opinion, his stuff sucks, or it did for his application. everything was redesigned (pullies, drive system, mounting system for the charger...everything). he almost has a 2.9 liter and this thing is rocks. the only reason he never made the huge numbers is because of belt slpiiage. i cant give any of his secrets away...that and i dont know all of them, he isnt telling. but i guess we all have are little secrets ![Wink ;)](./images/smilies/icon_wink.gif)
klze, custome supercharger setup, powerdyne BD 10 charger, holly fuel pump, full stand alone fuel managment (SDS) MSD ignition with blaster coil and much more..
Yup, i was thinking of Abrams. Not sure why I confused the two names but anyway....
My Cardomain site
My Cardomain site
- johnnyb
I'd be interested in seeing a dyno sheet for your car just to see what the actual hp and torque is. You wou;dnt happen to have one would you?
![Image](http://i49.photobucket.com/albums/f292/amun931/mx3.jpg)
