BPT swap question
BPT swap question
Hi guys, next week I will buy a BPT engine and I dont know what I need to install it (with the exception of the motor)...please help
Re: BPT swap question
not trying to rude, but you've made things extremely hard on yourself by not researching this HUGE task. you now have a motor, but are still missing a lot of parts. the site has a search feature along with a 4cyl FAQ to help you out.
bpt info
bpt info
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
Thanks for the info..and by the way nice car...but I heard that for the DOHC MX3's you only need the motor, an ACT clutch and a custom Intercooler...is that true?
Wrong.
2004 Nissan Xterra - Daily Driver
2003.5 Mazdaspeed Protege - Sold
1994 MX-3 RS - Selling
Searching for a new performance car to buy, cant decide.
http://www.sounddomain.com/id/omenmx3
- ryanlindenberg
here is a list of some of the stuff that i'm buying for my BPT swap in my 95. there is still more than this.
BPT Motor
Fuel Pump
Clutch slave cyl
haltek e6x or e6k
intercooler
blow-off valve
intercooler plumbing
clutch
transmission
protege 90-94 belts DOHC
EGT guage + probe
Boost guage
A pillar pod
2nd gen MX6 V6 speed sensor
exhaust piping
exhaust flex-pipe
high-flow cat
muffler
MSD Ignition???
drive shafts
misc.parts
protege clutch
SS clutch line
BPT Motor
Fuel Pump
Clutch slave cyl
haltek e6x or e6k
intercooler
blow-off valve
clutch
transmission
EGT guage + probe
Boost guage
A pillar pod
exhaust piping
exhaust flex-pipe
high-flow cat
muffler
MSD Ignition???
drive shafts
misc.parts
protege clutch
SS clutch line
CARDOMAIN WITH UPDATED PICS
Can I use a 96 Protege LX transmission? or a KIA Sephia (1.8 DOHC) transmission?....
I Believe with protege lx and escort gt 1990 to 1995 will have your tranny (front wheel drive tranny that comes off the BP). I dont think the 1996 pro lx tranny will work. The Kia im not sure.
1990-1994 Protege LX and 1991-1996 Ford Escort GT transmissions work. There is tons of info on this site, do a search.
<insert shameless plug>
V
V
BPT SWAPED MX FOR SALE!!!
http://www.mx-3.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=2;t=007118
http://members.cardomain.com/ricerocket666
AIM: l3acardiRon151
AIM: l3acardiRon151
- Franko
Most of this stuff you dont really NEED. If you are totally serious about getting everything done at the same time then by all means get everthing here but it is to my understanding that you dont need a new fuel pump or an intercooler or a halteck which costs more than the bpt itself. The way that I am going to do it is I am going to get just what I need to get the engine to work for now and then as time passes I may choose to upgrade to better parts.. It is not like I am going to be bringing the car to the track or anything.. it is just a daily driver. If you were to go out and buy evertthing on that list you are guaranteed to spend like $10,000. You do need most of those things on that list but alot of them are optional. The bpt swap is not as bad as it seems. I have been talking to the guys at mazda.. I am even thinking of getting them to install it for me.. they said it would cost like $1000 cdn which isnt really that bad when you consider whats involved.Originally posted by ryanlindenberg:
BPT Motor
Fuel Pump
Clutch slave cyl
haltek e6x or e6k
intercooler
blow-off valve
clutch
transmission
EGT guage + probe
Boost guage
A pillar pod
exhaust piping
exhaust flex-pipe
high-flow cat
muffler
MSD Ignition???
drive shafts
misc.parts
protege clutch
SS clutch line
All I am saying is that right now I dont even care about maximum performance... as long as the bpt works as well as it did when it was in the 323gtx then I will be happy... ...for a while anyway
Anyway thats just my 2 cents
Mx3_pr and ryanlindenberg I wish you guys the most best of luck with your swaps.. I hope everything goes well for you and for me.
<small>[ February 04, 2004, 08:35 AM: Message edited by: Franko ]</small>
- ryanlindenberg
it's only gonna cost me like 5-6k. i figure if i'm gonna put it in i might as well do it all at once so i only have to tune it once. and the extra power will be fun too. all i have left is the clutch, haltech, intercooler, and the intercooler/exhaust plumbing which i will have to do after the engine is in.
- Franko
Yeah man.. I completely agree with you... that is the best way to do it but if you really wanted to get the motor in but your cashflow is not the best right now then you can do it a little at a time.. it dosent seem like as much when you do it that way either..
Plus when you do it a little at a time you appreciate every individual thing more. Like if you did everything at once it would be deadly fast but then to get anymore out of it you gotta spend big money.. but if you just do a little at a time like putting in an msd ignition you will notice it and be like "man this msd rocks" and then you get a better clutch and youre like "man this clutch bites!!" lol well you get the idea..
- ryanlindenberg
that's true but i have 9 months of winter where i live, and no heated garage. i don't make much money but with that much time to save and collect parts i'll be ready to install in the spring. i have a motorcycle too so down time for my car isn't a problem as long as it doesn't rain hard.
the trans from your dohc car will bolt, the only trick is the right cv joint you can either machine the half shaft mount or simply remplace it with a cv joint in one piece from a sohc.
then you will need the bpt a good 200mm clutch set, bpt ecu and some one who really know how to trick wiring.
protege lx wiring as a base wiring + protege lx afm,coil,igniter.
custom intercooler+ piping
new belts and timing belts for a bp dohc
assuming you pay 1600 for engine +ecu
add 1400 for the remianing parts
add the time to do the swap
and it's done.
and it's done.
michel
323 gtx
323 gtx
