Battosai's turbo K8 piping
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
Re: Battosai's turbo K8 piping
Thank you very much Ryan! <p>[ March 08, 2003: Message edited by: BATTOSAI ]</p>
European Mx3 GsRT
Looks very nice.. Have you fitted the turbo on it and bolted it up yet?. next step is ceramic coating!! post some more pics if you got em!
DRAG SPEC MX3 BEING PARTED OUT.
BUY ALL MY STUFF OR DIE.lol, SERIOUSLY BUY MY STUFF. PLEEEASE
- mrspanky79
Battosai very nice job. Have you tried fitting it yet and made the return pipe. With the way you have it set up it looks like its going to be real hard to fit the return pipes in there and make it line up with the rest of the exhaust.
War does not determine who is right, war determine who is left!
94 mx3 GSX Stroked Turbo'd and Intercooled
99 vitara 4x4
99 vitara 4x4
So you're mounting your turbo where your oil filter is?
David Coleman
anyone that has ever fabricated a turbo kit knows that there is not set position. things will change and you will have to move things. you go with whatever is best for your budget and your time. i think its a very good start, nice welds, smooth bends,, hope it sticks to that..<p>[ March 09, 2003: Message edited by: boostedmx ]</p>
Thank you very much for your appreciation, guys!
To all your questions I must say that I mount my turbo where my oil filter was, I already bolted it in it´s place, I plan to ceramic coat it and the downpipe has been fitted, but it has to be finished already. I have new pics of all my setup including details about the Intercooler and all related items. I´ll keep you updated!!
European Mx3 GsRT
Another point about the downpipe:
Note in the rear cyl bank that I enlarged the tube by 3 cm, in order to make the Down Pipe fit between the headers and oil pan with a little clearance. I also did those bends on the front bank header because that way I gained room. The front cyl. header also is enlarged 3 cm so it keeps both flanges at the same level. Not quite easy to do!!<p>[ March 10, 2003: Message edited by: BATTOSAI ]</p>
European Mx3 GsRT
Nice work. Here are the rest of the pics<p>
<p>If you have any more pix, hook me up man. Looks good so far.
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
<p>Here´s my complete piping!
I have been runing the car, but no boost yet! I think I must check the wastegate and the exhaust flanges gaskets for leakings. I found that both front and rear bank´s gaskets leak a bit, so I need to make new copper gaskets for an improved sealing.
Today I have purchased a Kl engine, so I´ll start to dissemble it as soon as I´ll receive it, in order to reinforce the bottom end and to port and polish the heads. I´d also like to make a custom intake manifold as Mici did in Mx-6.com on his car, with additional injectors. More to come soon!!<p>[ July 02, 2003: Message edited by: BATTOSAI ]</p>
European Mx3 GsRT
pics no worky
looks nice, good luck with everything, keep us updated
I'm bringing this post back from the dead, hopefully no one gets too mad
Anyways Battosai is this still running? Where did you move you oil filter to if you put the turbo right there?
98 Ford Ranger 3.0L
98 Ford Ranger 3.0L
