painting gauge bezel?
MarkMoore
Post by MarkMoore »
has anyone painted their gauge bezel? how'd it turn out? any pics? i'm guessing you just use the same painting process you would w/ painting any other interior piece? i guess you had to carefully tape off the little glowing turn signal arrows? any thoughts?........
1992 GS/RS Mutant Automatic
Pearl-JapSpec
Re: painting gauge bezel?
Post by Pearl-JapSpec »
u can buy carbon fiber ones and aluminum brushed ones of ebay for like $15cdn.
<img src="http://memimage.cardomain.net/member_im ... 1_full.jpg" alt=" - " />
Car Out Of Order For Now...
2 weeks In counting till re-incarnation!!
New G-Force Front Bumper!!
-_-_-_- Pics On Site -_-_-_-
http://members.cardomain.com/mx3_junkee
Teal_93
Post by Teal_93 »
Yes the same painting process. No you don't need to tape off the turn signals they just pop out of the bezel. I painted my dash parts with silver. Looks awesome.
I like it better than the white guages on the black bezel. I'm at work right now so I can't post a pic, but as soon as I get a chance I will post some.
Hope this helps.
MarkMoore
Post by MarkMoore »
thanks....
MarkMoore
Post by MarkMoore »
dang man, u're still at work after 3 days? isn't that against some kind of labor law or something? i'll give you the number of my lawyer...
Teal_93
Post by Teal_93 »
Technically yeah I'm still at work :confused:
Teal_93
Post by Teal_93 »
Here you go!!! These are pictures of my painted dash. Only cost was spray paint.
<img src="http://memimage.cardomain.net/member_im ... 5_full.jpg" alt=" - " />
<img src="http://memimage.cardomain.net/member_im ... 6_full.jpg" alt=" - " />
MarkMoore
Post by MarkMoore »
wow looks great... i'm gonna paint my bezel white... i was thinkin if it didn't look good on your car i'd go for the CF one, ha, but thanks for bein the one that did it first!
Teal_93
Post by Teal_93 »
Thanx for the comment & good luck on your dash.
Reprobation14
Post by Reprobation14 »
WOW, i really like that silver!
I found this stuff at a local shop that has bits of silver metal in it, and its pretty reflective.... I was going to paint my dash with that, but now that i see your dash, i think i wanna go the same route you did...
What paint is that?
Did you sand at all?
How many coats/clear coats did you use?
That shiz looks smoooooth like glass :D
-Chris
Chiggles
Post by Chiggles »
Props to Teal; nice paint job, man. :D
What I drive: A Cybertronian disguised in the form of a Creek Blue Mica 95 MX-3 GS. :driver:
Long term goal: Fabricating a new transformation cog! :welder:
Teal_93
Post by Teal_93 »
The paint I bought at my local hardware store it is a metallic silver. I used no primer or clear coat. All I did was wear plastic gloves & cleaned my parts with rubbing alcohol & a sponge. If you have an air compressor blow them off it helps. Do not touch the part with your bare hands you will have trouble with the paint.
I just cleaned the parts let them dry then just sprayed them with silver in many light coats. Don't hurry or it will look like crap. I had the quick dry paint so I could do a coat every 15 minutes.
Taking apart the speedometer & dash is a very easy task. I think anyone could do it.
If you would like a small removal & install sheet I could type one up.
If you have anymore questions e-mail me at yttaf1@hotmail.com
Good Luck
MarkMoore
Post by MarkMoore »
pearl-japspec... u have 319,xxx miles on your car????!!!!!
mitmaks
Post by mitmaks »
ive got c/f one and i love it, just sticks onto stock one, looks neat
bmwm3guy
Post by bmwm3guy »
Return to “Appearance”
