need opinions on taillights!
Re: need opinions on taillights!
Only thing i hatea bout the chrome ones, and the reason I think they look cheap & crappy is how the outer rim of the lights has a black line. Just shows you how crappily constructed they are.
At least that line is hidden on the black & cf ones. It'd be better if there wasn't a line like that. from a rear angle you can really see what i'm talking about.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
yes, better go with black or cf ones!
- FIMotorMX-3
I have to admit, I don't like altezza's much. It's been said many times that they are RICE.... but if you were to go with them, I'd go black or carbon. I do give Atlanta a thumbs up on the red ones though. I've been wondering how they would look if they whole lens was red. Not bad man..
sold it to a friend.93 green MX-3 with ZE swap. KL36 ecu, modified carbon fiber intake from a civic hatch. Centerforce Dual Friction clutch from MX-6. black Konig Minuz wheels, Synthetic fluids, 3 gauge pillar pod with air/fuel, water temp and oil press. Autometer Shiftlight. B&M short shifter. 2.25 piping with a Greddy SP1 muffler, AWR urethane front motormount, pheno spacers, Intrax Springs, Mazdaspeed Sideskirts. The New Ride is a 2003 1.8t a4
check out myspace:
http://profile.myspace.com/index.cfm?fu ... D795345349
my cardomain: http://www.cardomain.com/ride/2142324 UPDATED!!!! 08/28/06 newest pics
check out myspace:
i see alot of chrome and black ones
go CF i dont see to many of those
if you want something different....try this
<img src="http://memimage.cardomain.net/member_im ... 3108_3.jpg" alt=" - " /> <img src="http://memimage.cardomain.net/member_im ... 3108_4.jpg" alt=" - " />
IMO...The blacker the better. Im gettin the black ones for my Teal car, but its gettin painted black. I think the chrome ones only look good on the nissan Altezza edition cars because they were the ones who started the thing. I see so many riced out hondas, cavaliers, and sadly my girlfriends Focus, with then. The black ones are more unique, which is what the MX-3 is all about, right guys?
the Lexus Altezza started it all.... well the IS300 now.... am i correct?
My bad, you're right. Im just used to the maxima and altima aruond here I guess
pretty sure it was the is200 that started it
I've got the stock mica blue on mine, and although silver does compliment fairly well with blue most times, in this particular case, I think I'm going to have to go with the black Altezza's for the fact that the chrome has been played out to the point where it cheapens the appearance, but mostly cuz since the mica blue is just so dark, black will probably end up being a smoother match.
Slightly off topic though, has anyone here ever have an issue with the fit of aftermarket tails? I've been told that they don't tend to have quite the same exact fit as the stock ones, and because of that, some people have experienced fog-up or moisture leakage within the lenses. Has this ever been a problem for anyone, and if so, what did you do to fix it?
What I drive: A Cybertronian disguised in the form of a Creek Blue Mica 95 MX-3 GS.
Long term goal: Fabricating a new transformation cog!
If you must change your tailligts, get the black Altezzas. Chrome looks cheap.
<img src="http://blackmagic.homepage.dk/lowered3.jpg" alt=" - " />
<img src="http://img.photobucket.com/albums/v187/ ... tokico.jpg" alt=" - " />
EDIT: The cars on the pics are SIXPACK's and Solo's.
<small>[ December 06, 2004, 09:08 AM: Message edited by: Macen ]</small>
toyota altezza. Stateside it was the lexus IS300. Lexus only exists in north america
DONATE TO MX-3.COM
DONATE TO MX-3.COM
- garfy1981
I did a post on what rear clusters would look the best on my silver mx3 and decided the altezza wouldnt look as good on silver. But black/cf altezzas look damm good on black mxs. In the end I tinted my standard lights red and am damm impressed with the results. I masked off the reverse, and changed the standerd lamps for hyper bright led lamps, even these shine right through the red tint in orange for indiction, they make a big difference and keep everything legal.
2.5 Ze straight neck, blitz intake, mazdaspeed engine mounts, fidenza flywheel, CM II Clutch, KL-36 ecu, Magnecor 8mm Leads, Battery Relocation. Hotshot headers, 2.5 mandrel bent stainless exhaust, hi-flow cat, Speed hut dials, custom coilover set up. Custom willwood big brake conversion.
Altezzas usually look bad all together. Perry had a real good idea and I do like the way his looks. Good job again Perry, you da man.
Yeah altezza's seem like they have worn their welcome everywhere. You just see them on every car. I was toying with the black lights on my car(which is black). But I decided after seeing a couple cars that have their lights tinted red. That i'm going to do that instead. Its alot cheaper too!
THIS USER HAS BEEN BANNED, DO NOT DEAL WITH HIM. - MX-3.com Admin
