Pacesetter sts question...
Just ordered a pacesetter sts and was wondering if i should also purchase new bushings? I did a search and in some other posts people have said that only 2 fit in the corksport $30.00 kit... is this correct? Is it really worth it, e.g. how will they help with the aftermarket shifter.
Re: Pacesetter sts question...
The pacesetter sts uses different bushings on than the stock shifter. By that I mean the ones on the bottom of the shift lever.
What bushings are they then?...
Pacesetter made their own bushings for the shifter. And I tried to contact them a long time ago for replacements but no answer. And I remember that on their website doesn't list any part #'s for the bushings for the mx3. So as far as bushings go... you're **** out of luck.Originally posted by KU MX-3:
