How do you remove the stock antenna?
I looked at it and it can't see how you remove it. I wanted to just yank it off but I don't think that's the proper way of doing it. I already cut it shorter and I plan replacing it with something much smaller.
My Cardomain site
My Cardomain site
Re: How do you remove the stock antenna?
there are 2 screws, take them out, then just pull off the hard plastic part thats holds the antenna in. its like glued on.. ut beware when u take it out and u remove the antenna it will break...
2 more weeks....
Yes, I have that part figured out. I want to totally remove it from the antenna wire. There are two different cables hooking onto it. One of them may be able to be yanked out but I just don't see how the other one can be.
My Cardomain site
My Cardomain site
- johnnyb
the other one may hook up on the stereo side.
- mitmaks
i hate people that 'just yank it all out' all the time, its same kind of people that had my charger, molesting cars, people like that should drive geo metros... btw yes that other wire disconnects on back of player.Originally posted by Sik Blu MX3:
idk i just yanked everything out
