Would it be hard to find mounting points? Any suggestions? Comments? Words 'o wisdom?
'92 MX-3...all stock...GAH! I NEED ME SOME MODS!.....
Take it to Mazda and have your belt track replaced (its recalled under campaign 72803). Personally I wouldnt go modifying the seatbelts unless you can get ALL of the stock hardware you need out of the right donor car (if you can find one). The mounting locations may already be welded in place, you'd have to pull back your carpet and trim to find out for sure. Also dont go substituting cheap Home Depot hardware or you may find yourself flying thru the windshield when you really arent in the mood to.Would it be hard to find mounting points? Any suggestions? Comments? Words 'o wisdom?
...must...get...stickers...make...car...go...fast...
if i could only of done that. mine got locked in the open door position... luckily the dealership is fixing all that crap for free before they get ne more money out of me. luckily, the part arrived today, so my 93 RS is commin home tommorow.Originally posted by Gimpmonkey:
Yo, fellas...thanks for the info...much learned, much appreciated, will probably yanked the thing back 'til it locks, then just duck under the belt...kool......must...get...stickers...make...car...go...fast...
