Clear corner lights
Clear corner lights
Hey i just received my clear lights from Corksport. I thought that the back side lights would also be included. Do I have to order some more clear lights for the back, which are the same as the side marker lights for the front. Also could someone put the FAQ on putting in the corner lights without the housing. I'm putting my lights in tomorrow and I need the directions
If you love something let if go, if it comes back to you it's yours. If it doesn't, it never was.
Re: Clear corner lights
ok man, you got the clear blinkers without the housing? ive seen walkthroughs on this, what alot of people do is blow a hair drier into the stock blinker till the sealent gets soft, then you carfully clip them off the housing, then install your new ones with a fresh sealent, also ive seen a guy put his oven on LOW and put them in there till the glue was soft, i hope that helps, i havent done this yet but it seems very easy, good luck. also if you have time and like 10 bucks pic up some silver spray paint and paint the inside of your housing, gives it a nicer look, rather then seeing that yellow color.<P>Tim Dawson
- Andrew_Pakula
Here is a link to detailed instructions with pictures:<P><A HREF="http://www.mx3gsr.freeservers.com/clear_inst.htm" TARGET=_blank>http://www.mx3gsr.freeservers.com/clear_inst.htm</A>
