Anyone break a gauge needle installing indiglo
I broke my gas gauge needle installing my indiglos.. Maneuvering the indiglo over the gauge was ridiculous. I took my time.. and still ended up breaking a needle. Has this happened to anyone? The little metal stem snapped. How can I fix this?
Re: Anyone break a gauge needle installing indiglo
actually, when installing my speedhut reverse gauges, it was too hard to have them screwed into the cluster that i took off each needle to finish the job. the rpm and speedo needle was easy to put back on, but it's a b---- trying to put on the temp and fuel needles...i STILL have them on crooked today and am too lazy to fix it!
- team slideways
- team slideways
Ok I got a way to do them if you think your going to brake them<P>Do every thing the same the tack and speedo are eazy the problem everyones having it the temp gas and clock combo<P>this is what I did, turn the guage cluster around you will see 3 screws for the fuel gauge and 3 for the temp undo them and the gauge will come out, now you dont have to worrie about the clock, you now grab the 2 gauges by the bottom round parts, sqeeze them together a bit and you will see the old gauge will flex a bit and you can slide the new gauge over eazily, then get a small screw driver and remove the screws holding down the gauage face one at a time slide over the shaft of the clock put the 6 screws back and your done<P>ps. what did you guys do with your clocks did you know the the cover over it is tinted yellow and the LEDS are really blue if you replace the cover with a clear or tinted cover it will be blue
i put my gauges back in... can I really make the clock blue..cuz green isnt cutting it, Cuz i also wanna make the turn signal arrows blue. Has anyone done this before
i just broke mine too on my temp guage. Did you fix yours or do i have to buy a new guage cluster?<P>Larz
I bought a new gauge cluster, I broke the gas needle bad... but i didnt break my temp gauge. If you want I'll sell you the temp gauge you can just take out the needle and backing and switch it on to yours.
alright that would be the easiest way. how much do you want?<P>Larz
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by SmokyMcGee:<BR><STRONG>i put my gauges back in... can I really make the clock blue..cuz green isnt cutting it, Cuz i also wanna make the turn signal arrows blue. Has anyone done this before</STRONG><HR></BLOCKQUOTE><P>what i did was take out the cover, pop out the little plastic arrow pieces (they're green) and make new ones out of clear plastic and spraypainted it with candy apple blue paint...candy apple is transparent so you'll be able to see the light through it...and i put them back.<P>hey how did you put on the old needles onto the new gauge? i'm trying to put mine back in and they don't want to stay in there without getting stuck diagonally.
- team slideways
- team slideways
I didnt switch the needles, I switched the whole circle peice with the two gauges(gas/temp) .. now i have left over is my old circle peice with a broken gas gauge..but the temp is all in good shape. In Jeff abrams site he says that you have to heat the glue under the needle so you can pull it off by using two spoons to lift it evenly. Did you break the shaft it is on..or the needle from the base of it? If its the shaft...then I would say buy another gauge cluster cuz I snapped the shaft off the gas one and tried fixing it for 3 hours till i said screw it.
I popped the gas needle off putting the face on. I didn't break it so I put the needle back on. Now the gauge doesn't work. ![Sad :(](./images/smilies/icon_sad.gif)
yea same thing here as pelado. the needles didn't break or anything. they're all intact, they just won't go back into the hole. the needle that i took off has the little metal rod connected to it.
- team slideways
- team slideways
hahaha, u guys are brutal( no offence), i put them in for the first time amd they work fine! <BR>how in the world did u ever brake the neeedles! ![Very Happy :D](./images/smilies/icon_biggrin.gif)
Derek Van Horne MX-3.com Member # 33
![Image](http://www.gtcars.ca/gallery/files/3/0/0/4/signature.jpg)
94 MX-3 Silver Stone Metallic CAR is SOLD
Car Domain Web page MX-3
Car Domain Web page SRT-4
well they wouldn't fit, even if i sanded the needles...so i pulled them off...not break them...and put them in that way. i had to take out the stock gauge to fit the other one in because the one i ordered were made for a gs, but i have an rs....the only real difference is the size of the stock gauge.
- team slideways
- team slideways
