Restoring and painting rims
Brainless
Post by Brainless »
I'll be buying some 15" used wheels from a 95 mx-3 GS (the 5 spoke ones) and I want to know if there's any way I could make them look like new and possibly repaint them MYSELF.<P>thanx for your help ;)
Jonathan Michaud
93 Red RS
Brainless
Re: Restoring and painting rims
Post by Brainless »
...anybody? :confused:
Jonathan Michaud
93 Red RS
ssmog
Post by ssmog »
Brainless, take the rims to a place that does sand blasting and have them "bead blast" them with glass or plastibead and then have them Uerothane the rims, once dried they will look brand new.
Commit yourself to a Psychiatric hospital before the rest your sanity disappears, and you are strapped in a chair, fed mushy peas with a rubber spoon with only your tortured fantasies for comfort....
ssmog
white fish
Post by white fish »
you can get them powder coated for aroud $400<P>and someone told me you can get the anoidzed for like 5 or 6 hundred
mxer4eva
Post by mxer4eva »
Alright man here's a cheap way of making your rims look like new. You go and have the tires taken off and then go out and get simple green and AtoZ simple mag cleaner by eagle one and use those to remove most of the dirt and stuff that may be on it. <P>If there is still some stuff dirt attached to the rims, you can sand the dirt off and make sure that its all smooth and clean. Then go to a paint store and you buy rim paint, its made especially for rims and you paint them, buy a good clear coat and clear coat them. let dry and put the tires back on. Worked on mine should work for you.
1993 GSR - Black with CS Mazdaspeed style front and sides skirts, KLDE and a bunch of other mods. Patiently awaiting a T3Super60, intercooler,MSnS and a custom fuel rail.
1993 VW Corrado SLC- completely stock. (May she R.I.P)
codene
Post by codene »
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>. Then go to a paint store and you buy rim paint, its made especially for rims and you paint them, buy a good clear coat and clear coat them. let dry and put the tires back on. Worked on mine should work for you. <BR> <HR></BLOCKQUOTE><BR>my friend did the same thing on his civic. they look pretty nice although my powder coated ones look better. you dont need to go to a shop. they charge outrageous amounts. find someone with a gun. one of my friends club had one and i powdercoated my rims for a little under $100 between cleaner,paint, and coats.
<A HREF="http://www.geocities.com/mail_cory_here" TARGET=_blank>Codenes Car</A>
Return to “Appearance”
