[/QB][/QUOTE]Originally posted by Yoda:
Around here there are about 6 or 7 JDM engine imports in town and they get at least one of the AWD tranny on a KL-ZE in each consignment. Since there is no demand for them they go in the big blue bin. The only difficulty is to wire up the center diff. servo, cutting the floor for the both fuel pumps and wire the the transfer pump so that it is not running continously. Also the AWD on the KL-ZE you will need the ECU and tranny control module.
Last time i checked there were not AWD trannies for the Klze its an LSD tranny. And you wont need the control module on a manual nor do you need the klze ecu you can use a kl03 ecu and it will work.
