klze misfiring, bogging, backfiring
i went to the tracks with my ze the other night. everytime i floored the gas, once i hit 6000 rpm it would bogg down and backfire. i would have to let out the case and then floor it again but at 6000 rpm it would happen again. my friend spectating said i had a lot of black smoke from my exaust. it only happened at 6000rpm and up. i adjusted my safc 2 to lean out the fuel mixture thinking it was to rich but it only helped out a little. could this be my timing or does anyone else have any suggestions. this never happened before an i assumed it must be timing cause i just serviced the water pump and timing belt. thanks for your help
Re: klze misfiring, bogging, backfiring
What ECU are you using. I have a similar problem becuase Im not using the KLZE ECU
93 GS, KLZE, KL31 ECU, Centerforce Stg 3 Clutch, 2.25" Exhaust w/Flowmaster muffler, OBX Headers, Pheno Spacers, Front & rear X-drilled/slotted Rotors, KVR pads, SS brake & clutch lines, Ractive Filter, H&R Springs, Tokico Blue Struts, 8mm Accel Wires, MSD 6A w/ Blaster 2 Coil, HVAC Indiglo Panel. *Sold*
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
i have the kl-36....its the right ecu
- papa roached
what vaf
the k8 vaf
is it a coincidence that the last vris setting is at 6250? (both closed)...
i got nothing sorry![Smile :)](./images/smilies/icon_smile.gif)
i got nothing sorry
Tom Alexander
is there a way to disable vris so that you've got max airflow at all times? or is it better for it to be on?
![Image](http://img.photobucket.com/albums/v386/zemadman/mx-3/ef032050.jpg)
- papa roached
with the VIRS on it will give you better mid range power but with them off you will get a bit more up top but every thing i have seen says keep the VIRS there cause you will lose alot in 1/4 mile times and that means you dont gain anything
The VRIS ensures you get maximum airflow by tuning the induction tract to minimise inertia effect on the moving air.Originally posted by ZEmadman:
Less inertia = More air into the cylinder
Extra thick soundproofing in the boot (trunk) to quieten my stainless steel exhaust system![Smile :)](./images/smilies/icon_smile.gif)
i had a similar problem. the car would stumble at about 5000 rpm and then it'd accel fine past that.
I replaced both O2 sensors, and now the car runs flawless.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
Had the same problem.. bad vaf, replaced vaf with new one, runs like sex.
1992 Mazda mx3 gs / 03 / ms8 intake manifold / klze 67mm bored TB/ Custom CAI / 2.5 Custom exhaust / Drift kit front and sides/ CF Invader hood / 17'' MSR gunmetals with chrome lip / Tockico Blues / Suspension technique springs / Leather interrior/ B&M SS / Fully customized interrior (Red and black) / Corvette Red 00 Paint w/ white,blue,gold pearl / Shaved altezzas w/ black trim/ Front rear strut bars / ze ecu ( I think that's all )
